1994 Dodge Caravan Heavier duty struts, shocks
1994 DODGE CARAVAN
CORCORAN
Suspension problem
1994 Dodge Caravan 6 cyl Front Wheel Drive Automatic 124K miles
Hi. This is a conversion van with 5,000 miles on new struts and shocks. It's already bottoming out on smaller bumps and clearly needs heavier duty equipment. How do I find that? I've run through the Monroe shock "picker" but don't know that does it. I suspect shocks and struts for a PU would do but don't know about fit.
If the fellow who answered my question regarding the Transmission Control Module would pass I'd appreciate it. All that information was wrong.
Feb 21, 2009 at 3:22 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Hi:
I'm sure heavy duty struts are available from many of the manufacturers. However, something for a truck would not work. You may want to check into purchasing the complete strut assembly that comes with the strut, coil spring, strut plate... perhaps you would find something designed for heavy duty service like that.
Feb 21, 2009 at 7:31 PM
