1994 Dodge Caravan fuel not up to the fuel lines
DENEEN36
Computer problem
1994 Dodge Caravan 6 cyl Two Wheel Drive Automatic
my van won't crank after putting used fuel pump on
can you tell me what to do to get my car back running? I got the part from junk yard
Oct 5, 2010 at 12:15 PM
  • 75,988 POSTS
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Oct 5, 2010 at 12:40 PM
