1994 Dodge Caravan Engine shut down while running
154,000 MILES • 6 CYL • FWD • AUTOMATIC
GUYSTUTZMAN
Vehicle was running fine. While stopped at a traffic light, the engine quit running. The starter would not engage, all electrical functions, i.e. lights, radio, have no power.
Battery terminals are corrosion free. Attempt to jump failed. Suspect battery cables are broken inside the covering. Do you have any other areas that I can check? Thank you.
Sep 6, 2008 at 11:16 PM
BMRFIXIT
  • 19,053 POSTS
check battery ,charge and or replace
get the engine started and check charging system
(BAD ALTERNATOR )
Sep 6, 2008 at 11:27 PM
