1994 Dodge Caravan Engine cranks normally but won't start
128,000 MILES • 6 CYL • FWD • AUTOMATIC
JQ102
When the engine warm up after driving for about 20 minutes and the engine stall when i stop at the red light or stop completely. I have to wait for 15-20 minutes for engine to cool down before to start the engine again otherwise the engine won't start when it's hot. Now the car dies and won't start any more even the engine is cold. I did test the spark plugs and none of them has spark when the engine is cranking. Please advise.
Mar 29, 2009 at 6:59 AM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Mar 29, 2009 at 7:32 AM
