HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Engine
Symptoms
Backfire
SPONSORED LINKS
1994 Dodge Caravan Engine backfires after heating at operat
CACOLIN44
MEMBER
1994 DODGE CARAVAN
4 CYL
2WD
AUTOMATIC
200,000 MILES
Complete fuel pump and filter kit have been replaced
TPS has been changed
Complete tune-up has been performed
Engine starts fine, idles ok, but after driving a few miles it starts backfiring and loosing power
SPONSORED LINKS
Sunday, April 19th, 2009 AT 8:32 PM
BLACKOP555
MECHANIC
Have you checked the igniton coil and ignition control module?
Spark plugs should be replaced and proper gap checked.
When vehicle runs bad check the spark. Is it bright and blue?
Spark plug wires shoudl be check for resistance. No mre then 10000 ohms of resistance per foot of wire.
SPONSORED LINKS
Monday, April 20th, 2009 AT 6:49 PM
Please
login
or
register
to post a reply.
Related Engine Backfire Content
1997 Dodge Caravan Car Back Fires And Shuts Off And...
What Is Wrong With The Van With A 3.3 Liter If It Back Fires From Engine And Then Sometimes It Wont But At Times It Will Shut Off When In...
Asked by
middle25
1 ANSWER
1997
DODGE CARAVAN
VIDEO
How To Fix an Engine Backfire
Instructional repair video
GUIDE
Backfire Repair
When your engine backfires it can do so in one of two ways. First and the most common way is when the engine is running a small explosion of unburnt fuel is ignited inside...
Misfire/backfire
Hello - I Experience Missing And Sometimes "backfire" (like A Popping That Seems To Come From The Exhaust) Mostly Evident On Sudden...
Asked by
cngsteve
1 IMAGE
1999
DODGE CARAVAN
Backfiring Through The Manifold
Changed Spark Plugs And Wires Van Ran Great For Two Days. Got Fuel As I Left The Station Car Bogged Down And Began To Backfire Through The...
Asked by
Gina Simmonds
2 IMAGES
1999
DODGE CARAVAN
Stumbles On Acceleration., Backfires Or Pops Under...
Caravan Starts & Idles & Runs Ok At Speed; Code Reader Gives Misfire On Cyl 2 Took Out Plug 2 To Find It Coated With Black Soot. Put Back In...
Asked by
JAMES FRANCIS
2003
DODGE CARAVAN
1996 Dodge Caravan Engine Backfires
I Have A 1996 Dodge Caravan With About 140,000 Mi. The " Check Engine" Light Came On, And Ever Since This Happened The Engine Is Constantly...
Asked by
mbeavy
1996
DODGE CARAVAN
VIEW MORE
SPONSORED LINKS
Intermittent Misfire
How to Repair an Engine Cylinder Misfire
Online car repair manuals
