1994 Dodge Caravan Changing front axle
6STRING
Drive Train Axles Bearings problem
1994 Dodge Caravan 136860 miles
I have a 94 Dodge Caravan and the right front u-joint has got one foot in the grave and it's fading fast. Do I need any special tools to change the axle. And after I get the covers removed will the top end slide out, if not what is the trick to break it loose. And how hard or easy will the new one go back in. Also do you have pictures of this process on this or anyother website.
Mar 7, 2008 at 8:48 AM
BMRFIXIT
  • 19,053 POSTS
you may have problem releasing axle nut
as for difficulty its not a walk in the park but not that bad
remove axle nut
tire out
brakes out
lower ball joint out from the hub
separate axle from hub
pray inner axle out of the tranny
Mar 7, 2008 at 12:39 PM
