1994 Dodge Caravan changing alternator
KEYBOARD KIM
  • 1994 DODGE CARAVAN
Electrical problem
1994 Dodge Caravan 6 cyl Front Wheel Drive Automatic
I need instructions for changing 120 amp alternator on 1994 Dodge Grand Caravan SE, 3.3 liter. Alternator has single groove serpentine.
Tuesday, December 15th, 2009 AT 2:00 AM
RACEFAN966
  • 5,029 POSTS
Ok first disconnect battery cables from the battery. Remove the drive belt, loosen but do not remove the the nut on the support bracket on the exhaust manifold. Remove alternator tensioner powersteering bracket bolt. Remove tensioner stud nut and tensioner. Remove alternator mounting bolts. Remove power steering reservior from alternator mounting bracket, but don't remove the hoses from the reservior. Remove alternator support bracket bolts. Remove intake plunum to alternator mounting bracket bolt. Remove alternator support bracket. Now move the alternator aside to remove the wiring from the back of the alternator and then remove the alternator. Install in reverse order.
Tuesday, December 15th, 2009 AT 10:47 AM
