1994 Dodge Caravan car won't run
KATTYLADY66
Engine Performance problem
1994 Dodge Caravan 6 cyl Front Wheel Drive Manual
I changed the filter and it still won't start
Oct 27, 2010 at 3:44 PM
  • 75,988 POSTS
Pick your symptoms below check it and get back with some testing results
**Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem,Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
**No crank at all/nothing/nada when key is engage to starting position
Could be a blown fusible link, the starter, starter relay, clutch switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
Oct 27, 2010 at 3:50 PM
