1994 Dodge Caravan brake fluid leaking
JAMES2028
Brakes problem
1994 Dodge Caravan 6 cyl Front Wheel Drive Automatic
I have break fluid leaking on to my rear back passenger wheele..is this a costly repair and can i do this my self?
Dec 29, 2009 at 3:47 AM
  • 110,251 POSTS
Can you tell if it is coming from a rusted brake line or does it appear to be leaking from behind the backing plate (brake shoe side) and be a bad wheel cylender? If you can't tell, you will need to remove the wheel and brake drum to inspect the wheel cylender.
Let me know what you find.
Feb 25, 2021 at 12:31 AM
