1994 Dodge Caravan
FORD90
Brakes problem
1994 Dodge Caravan 6 cyl Front Wheel Drive Automatic
I have a 94 dodge caravan and cannot get the drvers side rear brake drum off. Ive loosened the brake shoe adjustment screw all the way off(if thats what its called) and the drum still won't come off! Is there something I'm missing? Please email me if you have an answer at crookedycook@hotmail.com Thanks
Jun 28, 2008 at 8:46 AM
BMRFIXIT
  • 19,053 POSTS
A use of a hammer will help
give it couple of good hits and turn the drum then hit it should pup out for you
Jun 29, 2008 at 1:57 PM
JALOPYPAPA
  • 467 POSTS
Pry out the dust cap in the center of the hub. Remove cotter pin, keeper, hub nut and washer. Pull drum off. The outer wheel bearing will come out with it. You probably won't need to back off the brake shoes, but if you do, turn the star adjuster from the slot in the backing plate. This is also a good time to perform maintenance on the wheel bearings, which should be done every year or two.
Clean and inspect outer wheel bearing and repack it with wheel bearing grease. Inspect the bearing rollers and inner and outer bearing shell inside the hub and the spindle for scoring or pitting. Replace any worn parts. To remove the inner wheel bearing, pry out the seal on the inside of the hub and replace with a new one. If you need to replace a bearing, take the drum to someone with a hydraulic press to remove and install the shell. Or use a stout punch and hammer to drive it out and hammer in a new one.
To reinstall, turn hub nut finger tight. While turning the drum, tighten to only about 8 or 10 ft-lbs.--just enough to take out any slack and runout but where the drum still turns freely without any binding. Replace the keeper and install a new cotter pin. Replace the dust cap. Reinstall the wheel and check again for absence of play and free turning.
Jul 1, 2008 at 4:26 PM
KGDECKER
  • 10 POSTS
[quote:0c4f09abde="ford90"]Brakes problem
I have a 94 dodge caravan and cannot get the drvers side rear brake drum off. Ive loosened the brake shoe adjustment screw all the way off(if thats what its called) and the drum still won't come off! Is there something I'm missing? Please email me if you have an answer at crookedycook@hotmail.com Thanks[/quote:0c4f09abde]
Jul 1, 2008 at 4:49 PM
