1994 Dodge Caravan auto transmission
TIMOT4576
Transmission problem
1994 Dodge Caravan 6 cyl Two Wheel Drive Automatic
Hello I took down my valve body in my transmission to replace my shifting solenoid and the bearings came out of place.I would like a picture where these bearings go. How many bearings are they? There is one smaller I have 7 or 8 bigger bearings. It is a three speed transmission. Take the trans pan down. the filter off remove the back two metal lines and the valve cover comes down after you remove the bolts. There is a plate over the valve body that holds these bearings could you email me a picture of the top of the valve body and where thse bearings may go? Thanks let me know Tim
Jan 11, 2010 at 7:48 AM
CH112063
  • 1,320 POSTS
I have it, but I don't know where I can send it, if I have this picture, let me know how I can explain it or send it to you, ok? I have a scanner.
Jan 11, 2010 at 1:06 PM
TIMOT4576
Joe please scan the picture to my email chevytough_94@hotmail.com on the transmission thanks will be intouch
Jan 11, 2010 at 8:49 PM
CH112063
  • 1,320 POSTS
yeah, ok i'll draw ya a picture and it'll get it back on the road, ok?
not too bad
Jan 12, 2010 at 12:26 PM
TIMOT4576
[quote="ch112063"]yeah, ok i'll draw ya a picture and it'll get it back on the road, ok?
not too bad[ Ok however you can help there are 7 or eight bearings and one smaller if you can explain or show me where they go like a picture I would appreciate it on top of the valve body on the auto transmiission thanks/quote]
Jan 12, 2010 at 8:41 PM
TIMOT4576
Hello Joe on this autoi trans are the 8 bearings the same size?
Jan 13, 2010 at 6:37 AM
CH112063
  • 1,320 POSTS
yes, they're the same size, they are check balls for fluid to keep from draining back and causing delayed, harsh apply's to their respective clutches, ok?
Jan 13, 2010 at 12:27 PM
