1994 Dodge Caravan air bag light
MARELAYALA
  • 1994 DODGE CARAVAN
  • 6 CYL
  • 4WD
  • 332 MILES
My air bag light stays on. I changed the fuse. The light goes off. But when I use my rear window wiper the air bag light comes back on. Need to fix light for inspection. What can I do now? Help me thanks.
Tuesday, April 21st, 2009 AT 11:30 AM
JALOPYPAPA
  • 467 POSTS
I presume it blew the fuse again. Of course, you could replace it and not use the rear wipers before you go for inspection. My 95 Plymouth Voyager was recalled for this. Then put some kind of seal below the front cowl, up near the bottom of the windshield. Apparently, heavy rain (when you're likely to be using the rear wiper) was a factor in shorting something out.
Tuesday, April 21st, 2009 AT 11:46 AM
