i have a 94 dodge caravan keeps blowing fuel pump fuse just replaced fuel pump relay
Jan 9, 2010 at 7:13 AM
✓Experienced Mechanic
You need to remove the fuel tank and check to see if there are any burnt wires and remove the fuel pump and check to see if it is drawing too many amps. Chances are the pump is bad.
LEt me know what you find or if you have other questions.
