1994 Dodge Caravan 94 CARAVAN wont start
REXXIKA
Engine Performance problem
1994 Dodge Caravan 4 cyl Two Wheel Drive Automatic
WE HAVE DONE THE FAULT CODE TRICK. IT IS EITHER 1255 OR 112255. WHAT DOES THIS MEAN. STILL WONT START. PLEASE HELP. WE CANT GET HOME. THANK YOU SO MUCH.
May 26, 2009 at 2:57 PM
CARADIODOC
  • 34,414 POSTS
Code 12 means the ignition switch was turned off. Code 55 means that's the end of the message. These are normal.
What is the symptom? Does the engine crank but does not run? Is there just one loud clunk when you turn the ignition switch to crank, but the engine doesn't turn? Is there no loud clunk, just a light click from some of the relays under the hood?
caradiodoc
May 27, 2009 at 10:28 AM
