I hope you are up for this challenge. :-) I have a 94 grand caravan with about 170K miles and has been a GREAT vehicle. The problem started about 7 months ago and typically turning a corner in city traffic the engine dies. I have replaced the spark plugs, fuel/air filter, thermostat. I had the fuel pump checked and it is fine. The repair shop says there is no recorded computer error and I hate not knowing what else could be the problem. There was an issue starting the van and I had to giggle the column shifter, but have not had any issues with that for some time. Is there anything in the stearing wheel mechinism/column that could be shorting out and causing the van to die? When the van dies, I pull over the side of the road and put in park and it starts back up without any problems. Any ideas or what is left to check? Oh, I also replaced the starter. I hope you can help. Does this model van have an ISC motor and could this be the problem? What about the ECM relay or ignition switch?
Thanks,
Lynn
Thanks,
Lynn
Mar 23, 2008 at 3:30 AM
