1994 Dodge Caravan
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
4ETOM9
heater does not heat
Oct 30, 2009 at 9:46 AM
CH112063
  • 1,320 POSTS
All of a sudden? Does it blow out? You have the 3.0L V6 right? or the other one.
Is it a regular type or electronic where you just put the degrees in and it is automatic. Make sure you check to see if it has antifreeze. And not when it is hot. Check it cold first thing ok. Does the stuff feel the same where you switch the heat from cold to hot. Joe
Oct 30, 2009 at 3:42 PM
