1994 Dodge Caravan
4ETOM9
  • 1994 DODGE CARAVAN
  • 6 CYL
  • 135,000 MILES
Heater does not heat
Friday, October 30th, 2009 AT 4:46 PM
CH112063
  • 1,320 POSTS
All of a sudden? Does it blow out? You have the 3.0L V6 right? Or the other one.
Is it a regular type or electronic where you just put the degrees in and it is automatic. Make sure you check to see if it has antifreeze. And not when it is hot. Check it cold first thing ok. Does the stuff feel the same where you switch the heat from cold to hot. Joe
Friday, October 30th, 2009 AT 10:42 PM
