1994 Dodge Caravan
TRACEY6555
1994 Dodge Caravan
the van won't start/turn over. when you turn the key there is no click but the radio and lights work. we tried to change the battery and this did not work. help!!!
Oct 22, 2009 at 11:20 PM
JDL
  • 16,098 POSTS
Welcome to the forum, what is litre size of engine? Automatic? I'd check the circuits at the starter relay, in the power distribution center, under the hood. Voltage to the load side of relay is hot all the time. Voltage to the coil side of relay goes hot with key in the crank position. Use a testlite to check for voltage.
Oct 23, 2009 at 3:18 AM
