1993 Dodge Caravan won't start
260,000 MILES • 6 CYL • 2WD • AUTOMATIC
KAMMANE
In the last month or so, it happened thrice that when I was waiting for the signal to turn green, the engine stopped.I had to start it again, at times, it took 2-3 tries to start it.Every time it stopped, there was the sign to check for the engine oil.
Last week, when it stopped at a signal, it refused to restart.I got it towed to my garage.I've not been able to start it after that.It cranks, but does'nt start.I've already added some engine oil as it was slightly less than required.I've also checked the transmission oil, which is at its proper level.Starter does'nt seem to be an issue as the engine cranks as if it is about to start.
PS:The fuel in the tank is approx. 10 litres.
Please help
Dec 21, 2009 at 4:13 AM
RACEFAN966
  • 5,029 POSTS
OK so what I need to know is what engine 3.0 or 3.3 or 3.8ltr. Also I need to know if there is spark or not and if there is spark is there fuel? Get back to me and we will go from there.
Dec 21, 2009 at 5:19 AM
KAMMANE
The engine is 3 litre,The spark is there.The fuel indicator had turned on only 5 mins before the problem started.As mentioned in my first message, I know that there is still fuel in the tank.Also the engine oil indicator still remains,although the engine oil is sufficient.
Dec 21, 2009 at 7:03 AM
RACEFAN966
  • 5,029 POSTS
Ok so there is gas in the tank this means nothing other then you aren't out of gas. I need to know if there is fuel pressure. See without fuel pressure there is no fuel getting to the engine therefore it won't start. So is there anyway you can find out if there is fuel pressure? If not get some throttle body cleaner and spray it into the throttle body and see if will start. How did you determine if there was spark? Let me know what you find and we will take it from there.
Dec 22, 2009 at 1:50 AM
