Transmission at times does not shift from lower ranges
102,000 MILES • 6 CYL • FWD • AUTOMATIC
LINDA CAMPBELL
transmission at times does not shift from lower ranges to higher range unless you stop the vechile turn off the engine and after restarting at times it will sfift perfect
Feb 2, 2008 at 3:04 AM
VICTOR35MA
[quote:15d0a42420="linda campbell"]Transmission problem
1993 Dodge Caravan 6 cyl Front Wheel Drive Automatic 102000 miles
transmission at times does not shift from lower ranges to higher range unless you stop the vechile turn off the engine and after restarting at times it will sfift perfect[/quote:15d0a42420]
Either cases when fuel system or transmission sensors register an anomaly the fuel injection controller (ECU) and or transmission controller will send the tranny to limping-mode.
Possible cause:
Check out for any engine sensor malfunction or look for vaccum leaks they could take controllers to limp-mode as well.
Most likely: and this is my best guess:
1.-Engine got air. (cooling system) purge (bleeding) cooling system, find out air source
2.-Transmission relay is worn out. should be replaced.
3.-Dirt or oil at wiring connectors that is running voltage to transmission solenoids valves from transmission relay.
Likely:
1.-Transmission controller needs software upgrade. (lates firmware)
May 20, 2021 at 9:01 AM
