1993 Dodge Caravan trans problem
120,000 MILES • 6 CYL • FWD • AUTOMATIC
STANIU
so.my caravan has a little problem.it doesnt shift into 4th gear.in the 1 first gear it goes in very high turation and shifts into 2 gear around 30mph.something even higher.no matter how hard i accelerate it,it still shifts the same.the 2 and 3 gear work pretty fine i think.now.one of the many mechanics i was,told me i need to rebuild the gear box.another mechanic told me my gear box is blocked into a failure gear or something like that.anybody has any ideea?it could be the speed speed sensor the problem or i need to rebuild my gear box.thanks
Apr 13, 2010 at 3:02 AM
CH112063
  • 1,320 POSTS
If you have an overdrive transmission and it is shifting late or not upshifting a technician checks the fluid before testing the transmission control module for fault codes. Even if the trans is burnt, he wants to understand what caused it and where to focus his attention when repairing it. Did your mechanic check for any fault codes? If not he should. If it is staying in a low(2nd) gear this is called a limp-in mode and there may be other electrical issues also. ok
Apr 13, 2010 at 12:26 PM
