1993 Dodge Caravan timing belt
224,000 MILES • 6 CYL • FWD • AUTOMATIC
CHEVY_TRUCKS
i have to replace my timing belt on my van and do i have to pull the crank pulley to put the belt on or off the van. please reply chevy_trucks
Feb 20, 2008 at 10:16 AM
BMRFIXIT
  • 19,053 POSTS
[quote:e9436d0c0e="chevy_trucks"]1993 Dodge Caravan 6 cyl Front Wheel Drive Automatic 224000 miles
i have to replace my timing belt on my van and do i have to pull the crank pulley to put the belt on or off the van. please reply chevy_trucks[/quote:e9436d0c0e]
you need a puller (you may be able to rent one check at your local part or too rental place )
may I also suggest water pimp too
and check if you have an oil leak check and change cam seals
good luck
let me know
Feb 20, 2008 at 10:44 AM
