1993 Dodge Caravan Temp gauge
BENDERXR
Engine Cooling problem
1993 Dodge Caravan 6 cyl 198000 miles
I have replaced the coolant temp sensor and thermostat
and flushed the coolant.If you drive a distance the temp gauge all the way up and the check gauges light comes on.It will not do it if I run it without the thermostat which I replaced twice.
May 23, 2008 at 12:10 AM
LEGITIMATE007
  • 5,121 POSTS
check the wiring harness and wire to the engine coolant temp sensor
May 23, 2008 at 12:29 AM
