HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Engine
Symptoms
Idle High
1993 Dodge Caravan Shifts Slowly & High Idle RPMs!
SHAKYJAKE6977
MEMBER
1993 DODGE CARAVAN
6 CYL
FWD
AUTOMATIC
213,000 MILES
I need to know what causes this condition.
Wednesday, February 20th, 2008 AT 9:57 AM
BMRFIXIT
MECHANIC
Check fluids
check for a vacuum leaks
check engine tune up and operation
SPONSORED LINKS
Wednesday, February 20th, 2008 AT 2:36 PM
Please
login
or
register
to post a reply.
Related Engine Idle High Content
Running At A Fast Idle My Catalytic Converter Gets Red...
Is That Normal? If Not, What Could Cause It? Thank You. Car Pops And Sputters When Put In Drive And Quits. The Same When Start Up. Seems...
Asked by
Marvin Vik
1992
DODGE CARAVAN
1999 Dodge Caravan High Idle Speed On Start Up
I Have A 1999 Grand Caravan Wit Ha 3.3 Liter Engine. I Changed The Spark Plugs Today And Had To Remove The Throttle Body And The Sir Plenum...
Asked by
silevstri99
1999
DODGE CARAVAN
2005 Dodge Caravan High Idle Slow Decel
I Have A 3.3l V6 I Just Replaced The Air Filter With A K&n Filter And The Stock Plugs With Bosch Platnium 4's During The Install I...
Asked by
tow0369
1 ANSWER
2005
DODGE CARAVAN
Engine Revs Up
Wife Was Driving! I Was Not With Her. She Said That When She Pulled On To The Freeway The Van Went Sluggish Then The Rpms Revved Up To The...
Asked by
Garfred
1996
DODGE CARAVAN
High Idle 2006 Dodge Grand Caravan Sxt
Changed Spark Plugs Didnt Unhook Anything And Started It Up And The Idle Was At 1400-1500 And The Brakes Got Really Stiff Have To Push Hard...
Asked by
wenzelsam
2006
DODGE CARAVAN
VIEW MORE
SPONSORED LINKS
Vacuum Leak Test and Repair
Vacuum Leak Symptoms
Vacuum Leak
Online car repair manuals
