1993 Dodge Caravan rear window washer pump
1993 DODGE CARAVAN
96,000 MILES • 6 CYL • FWD • AUTOMATIC
BREWERHAYES
I recently replaced my rear window washer motor and pump. The motor works OK but I can't get the pump to work. I bought the pump brand new. And, I sucked the washer fluid through the hose all the way to the nozzle to make sure the line was primed. What could be the cause of the pump not spraying the washer fluid on the window?
Jan 20, 2010 at 2:40 AM
CH112063
  • 1,320 POSTS
If you can't hear the washer motor come on at all, the washer switch or washer and wiper module which gets input from the switch is inside the liftgate, you can use a test light to see where the signal stops.
Jan 20, 2010 at 12:01 PM
