1993 Dodge Caravan gas mileage.
JULYRIVER
  • 1993 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 88,000 MILES
I installed a K&N air filter, also changed MAP sensor, and TPS( Throtlle position sensor), my caravan has lost of power but iit is barely making 11 MPG. What should I check?
Wednesday, October 27th, 2010 AT 1:42 PM
  • 109,755 POSTS
Has the check engine light come on? Also, you wrote it has "lost" of power. Did you mean it has lots of power? If there is a power loss, have you checked the catalytic converter?
Friday, October 29th, 2010 AT 9:29 AM
JULYRIVER
Thank you for your advice. I meant lots of power, adicional to that I changed the oxygen sensor, and no codes are coming out from the computer. Lately I noticed a little hole in the catalitic converter, once I saw water coming out of it. I still do not know what is hapennig. Could it be the catalitic converter?
Friday, October 29th, 2010 AT 1:05 PM
  • 109,755 POSTS
You should get the cat repaired if it is leaking. It could have an affect on the o2 sensors and also, the MPG.
Monday, November 1st, 2010 AT 9:53 AM
