1993 Dodge Caravan driver side window not working
100,300 MILES • 6 CYL • FWD • AUTOMATIC
HINK424
  • 5 POSTS
I have a 1993 Dodge Grand Caravan mileage 100,000. The driver side power window isn’t working . The passenger side works fine. Anyone have the answerer. any information will be greatly appreciated. thank you
There is no sound when i push the driver side button. The passanger side control does not work either. I removed the switch and the wires to the passenger side are hot but the wires to the driver side are not. In the picture the wires in to the driver side control without power are the white and blue ones. [img:9fac60a09d]http://www.2carpros.com/forum/automotive_pictures/589849_DSC_0343_1.jpg[/img:9fac60a09d]
Nov 6, 2010 at 8:07 AM
CARADIODOC
  • 34,416 POSTS
Hi Hink424. Welcome to the forum. Do you hear the motor run? If so, the flexible plastic track is broken. I think you can get them at the car parts places now for less than ten bucks. If there's no sound, and if the passenger window only works from the passenger switch, pull the rubber boot back between the door hinges and look for frayed or broken wires first. If you find some, I'll copy and paste my fix.
caradiodoc
Nov 6, 2010 at 9:16 AM
HINK424
  • 5 POSTS
caradiodoc, Thank you for the welcome and the response! There is no sound when i push the driver side button. The passanger side control does not work either. I removed the switch and the wires to the passenger side are hot but the wires to the driver side are not. In the pictureI added, the wires in to the driver side control without power are the white and blue ones. Wish i new where the wires come from.
Nov 6, 2010 at 10:46 AM
CARADIODOC
  • 34,416 POSTS
Did you pull the boot back to look for broken wires?
caradiodoc
Nov 6, 2010 at 5:58 PM
