1993 Dodge Caravan does not start
200,000 MILES • 6 CYL • FWD • AUTOMATIC
LT56
when i turn key the van does not start /there is no sound at all. i just replaced the starter 3 weeks ago, so that isn't the problem. checked the fuses, battery power and connections and all are ok. when i turned the key in the ignition and went underneath to see if the starter was receiving power, it cranked when i touched the connection with a voltmeter and grounded it. does this mean that the ground is no good? i checked the mounting bolts and they were tight, however when i tried to re-tighten the ground wire to the starter connection, i noticed that the little bolt might be stripped. could this be the problem? what about the starter relay? the chilton manual that i have describes how to troubleshoot it but it doesn't show where it is. any help will be much appreciated, thanks.
Feb 1, 2009 at 6:54 AM
2CARPRO JACK
  • 11,533 POSTS
Check for 12 volts at the small wire on the starter with key in crank position. If it has power then the starter needs to be replaced. If none, then get back to me and we will figure out where it stops. Also repair the ground, it needs to be tight for the system to work properly
Feb 2, 2009 at 12:02 AM
AFLEWEL1
I have the same problem with my 1993 Dodge (128K miles). It's in garage now (face in) - doesn't jump, doesn't crank, no starter. I had AAA come on 3 different occassions and they did something as you described (pushing on a cable to get it started). I'd like a more permanent and reliable solution. Love the vehicle, but am always uncertain about where I'll be stranded and for how long due to this.
I'm looking forward to what you find out.
Feb 3, 2009 at 8:27 AM
LT56
found out what was wrong-- the neutral start switch was disconnected. apparently the plug popped out when i parked over a curb. thanks for the info though.
Feb 3, 2009 at 2:38 PM
2CARPRO JACK
  • 11,533 POSTS
Good find
Feb 3, 2009 at 3:51 PM
AFLEWEL1
Where are the "plug" and "neutral start switch" located that you're referring to? I want to get as much and as clear information as I can to go to my auto tech.
Feb 4, 2009 at 12:01 AM
2CARPRO JACK
  • 11,533 POSTS
On the trans facing the front of the vehicle, the plug is where the electrical plug into it
https://images.2carpros.com/forum/automotive_pictures/1639_Graphic_1.jpg
Feb 4, 2009 at 12:17 AM
AFLEWEL1
Thanks. I'll give this a try.
Feb 4, 2009 at 12:20 AM
