1993 Dodge Caravan coolant leak
ALYXKA
Engine Cooling problem
1993 Dodge Caravan 6 cyl Two Wheel Drive Automatic
what's the best way to find/stop a coolant leak? with the engine off i have a slow drip from the middle of the passenger side. with engine running, it drips alot & sprays a fine mist up under the hood on the passenger side. i cant see exactly where the spray or drip is coming from.
any ideas?
thanks.
Oct 9, 2009 at 6:09 AM
DOCFIXIT
  • 18,828 POSTS
What your describing seems to be the water pump if the half way on pass side is the fender or center of front of engine. If it is middle of firewall then heater hoses.
Oct 9, 2009 at 8:06 AM
