1992 Dodge Caravan Van wobbles when slowing down to stop
LEMONSALWAYSFINDME
Shakes or Wobbles problem
1992 Dodge Caravan 6 cyl All Wheel Drive Automatic
Hello, I just bought a 92 Dodge Grand Caravan and it wobbles or kinda jerks when slowing for a stop. The seller told me they just had the brakes & rotors done, can that cause the wobble if they weren't adjusted properly ?
Also my oil gauge is staying a little below the first line above the L even after adding 2 quarts of oil, where should the gauge range between the H & L ?
Sep 10, 2009 at 10:52 AM
  • 75,988 POSTS
While braking and car wobbles and brake pedal pulsates/steering vibrating-could mean warped rotors-
Do an oil/filter change-The higher the rpm the higher the oil pressure-if in doubt check the oil pressure with a mechanical gauge.
Sep 10, 2009 at 10:56 AM
