1992 Dodge Caravan transmission problem
135,000 MILES • 6 CYL • FWD • AUTOMATIC
QUIETSTORM024
My dodge caravan will go forward and backward, but the foreward will shift when I put the van in drive. what would be the problem.
Oct 21, 2009 at 6:10 AM
CH112063
  • 1,320 POSTS
Check the transmission fluid. If its still no good don't drive it until its checked by a professional.
Oct 22, 2009 at 6:22 AM
DAVID J MACK
Go to a mechanic and tell them the strainer on your transmission is clogged and you need a new one installed. The part itself costs about $12-15, and the work itself doesn't take more than an hour to do. Add in the cost of the fluid (likely 7 quarts), and it should be reasonably inexpensive.
Oct 24, 2009 at 9:21 AM
CH112063
  • 1,320 POSTS
I'm not sure I understand what you mean.
You have forward and backward, but it will shift when you put it in forward.
I think you mean the van moves forward and backwards but when in drive, it will not go into gear. Am I correct.
If that is what is wrong, let me know if the filter doesn't help. If it has fluid in it already, you may have to tow it. Since it won't shift? Sorry, Im not sure what you mean.
Oct 24, 2009 at 10:44 AM
