1992 Dodge Caravan RIGHT FRONT BRAKE STAYING APPLIED
NINIA
after replacing new brake pads, caliper, and rotor, my right front brake seems to not release correctly, causing the brake pad to over heat and smoke. what do i need to check next?
Nov 1, 2008 at 11:28 AM
JPAM
  • 307 POSTS
1. Incorrect adjustment of light switch.. <
2.Master cylinder pistons not returning correctly.. <
3. Restricted brake lines or hoses.<< well that makes sense. If something got in there when you replace them. Or some how didnt get the hose on right..
4. Incorrect parking brake adjustment..<< NO
5. Caliper piston sticking...aka CALIPERS << well if they where your old ones id say yes, but since you replaced them it turns into a no..
Although maybe you got a bad one.. Something blocking the release of fluid inside. The two steel guide pins not lubed correctly to give a free movement. Ask parts store if you can replace it. It just might be a free and easy fix..
Well dig into it thats all I got..
give use a shout back and tell us what you find
good luck
JesseS
Feb 21, 2021 at 5:19 AM
