1992 Dodge Caravan Replacing Transmission
MSGOFFNEY
Transmission problem
1992 Dodge Caravan Front Wheel Drive Automatic
Hello, I just purchased a rebuilt 1991 Dodge Dynasty transmission & I wanted to make sure it is compatible with my 1992 Dodge Caravan. Not sure which engine to choose above but mine is a 3.3L FWD. The Dynasty transmission is 3.3L, 4-spd (like my Caravan) & FWD. Can you please let me know if it is compatible?
Jan 28, 2010 at 7:56 AM
CH112063
  • 1,320 POSTS
it will fit, but you need to match up the transmission control module part number, it's on the TCM. or use it from the transaxle that your going to use, if the number supercedes to the one your going to use, it should be fine, a dealer will tell you the number it should be.
Jan 28, 2010 at 11:55 AM
