1992 Dodge Caravan radiator fan motor
LAURA JEAN
Engine Cooling problem
1992 Dodge Caravan 6 cyl Front Wheel Drive Automatic
was running hot, replaced radiator fan motor and heater coolant sensor. still gets hot
Apr 21, 2009 at 8:26 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Hello, Does the Radiator Fan come on? If not the most likely cause is the Relay and it is located on the inner frame on drivers side front under Radiator. Looks like this...
https://images.2carpros.com/forum/automotive_pictures/188069_coolantfanrelaychryslerdodge_5.jpg
Was the Thermostat ever changed? .
Apr 21, 2009 at 8:33 AM
