HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Engine
Symptoms
Not Running
SPONSORED LINKS
1992 Dodge Caravan my van wont start
HOTESTHETICS
MEMBER
1992 DODGE CARAVAN
1992 Dodge Caravan 6 cyl Automatic
My van wont start it has done this two times today. When you go to turn the ignition it wont do anything and my check engine like just flashes
Tuesday, June 3rd, 2008 AT 10:36 PM
BLACKOP555
MECHANIC
I would get the engine scanned for trouble codes to find out what is wrong.
Will it crank?
Try putting the vehicle in neutral does it crank? If so you probably have a bad neutral safety switch.
SPONSORED LINKS
Wednesday, June 4th, 2008 AT 8:25 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1992 Dodge Caravan Will Not Start
Engine Died While Driving. Cranks Over But Will Not Start. No Spark At Dist From Coil. Turn Key On 12 Volts To Coil Then Goes To Zero At...
Asked by
jmatesich
1992
DODGE CARAVAN
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1992 Dodge Caravan Will Not Fire
Engine Mechanical Problem 1992 Dodge Caravan 6 Cyl Front Wheel Drive Automatic Van Will Turn Over But Not Fire What Could Be Causing...
Asked by
westcoastrobin
1 ANSWER
1992
DODGE CARAVAN
1992 Dodge Caravan Won't Start
My 1992 Dodge Caravan Won't Start. The Battery Is Powered Up And We Have Interior Lights And Lights On The Dash. When You Turn The Key...
Asked by
emmilee
1992
DODGE CARAVAN
1992 Dodge Caravan No Start
Electrical Problem 1992 Dodge Caravan 6 Cyl Front Wheel Drive Automatic Key Tumbler Went Bad. Put New One In. Now Springs Back. When...
Asked by
aceone
1 ANSWER
1992
DODGE CARAVAN
1992 Dodge Caravan Engine Wont Start
I Stored The Van A Few Months Back And It Was Running. I Pulled It Out Of Storage And I Cant Start It. Tried Starting Fluid And It Will Run...
Asked by
ruffysanti
1992
DODGE CARAVAN
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
