1992 Dodge Caravan Engine wont start
150,000 MILES • 4 CYL • FWD • AUTOMATIC
RUFFYSANTI
I stored the van a few months back and it was running. I pulled it out of storage and I cant start it. Tried starting fluid and it will run for around 10 seconds and stop filled up the carb with gas and will run for a few more seconds tried to disconnect fuel line to carb to see if it spits out fuel while I crank the engine .... it wont what should I do
Apr 28, 2008 at 4:31 PM
LEGITIMATE007
  • 5,121 POSTS
do you hear the fuel pump turn on when you turn the key on? I have a check you can do for fuel pressure. your regulator is probably shot.
Apr 28, 2008 at 4:49 PM
LEGITIMATE007
  • 5,121 POSTS
go here to check fuel pressure
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Apr 28, 2008 at 4:50 PM
