1992 Dodge Caravan Dashboard Removal
212,000 MILES • 6 CYL • FWD • AUTOMATIC
DONIA0813
I want to remove the ENTIRE dashboard. I've removed all the instrument panels and all the screws and bolts I think will let me remove the dash but it still won't come out.
I have a Chilton-Haynes repair manual and have found it unhelpful with this problem.
Please advise.
Thank you,
Donia
Apr 5, 2010 at 3:44 AM
CH112063
  • 1,320 POSTS
Inside theres two 10mm(or 3/8ths) on each side. And on top, pull off the panel next to the windshield to uncover 5 more. These 7 are the main hold ins, another attaches to the heater box, if thats coming out with it no problem. If not, under the hood the a/c and heater hoses plus 5 more 7/16ths nuts hold the box tight. And the a/c drain hose, and vacuum for the box. Good luck.
Apr 5, 2010 at 1:07 PM
