1992 Dodge Caravan
170,000 MILES • 6 CYL • FWD • AUTOMATIC
MICK1223
what will happen when you got water in your traney it is 15 below outside and it will not go into gear what do i do
Jan 7, 2010 at 2:44 PM
  • 75,988 POSTS
Are you using water or did you dilute your antifreeze properly if not could be the transmission cooler compartment is leaking internally and mixing with tranny fluid
Jan 7, 2010 at 2:54 PM
