1991 Dodge Caravan dome light not working
105,000 MILES • 6 CYL • FWD • AUTOMATIC
THE SEATTLE GUY
the dome light does not come on when the doors are opened. the dimmer switch will turn them on as soon as it is engaged just a little bit (should not come on until slider is all the way to the right. so in order to increase the brightness of the instrument panel, I get the dome light on as well. I have replaced the complete switch assembly. What is wrong?
Aug 2, 2009 at 11:29 AM
CARADIODOC
  • 34,413 POSTS
Sounds like two different problems. First of all, turn the dash switch to a normal setting, (where the dome lights come on but aren't supposed to). Then go around to the three doors and press the switches in one at a time to see which one isn't turning off. Most commonly it's the one at the rear of the sliding door.. There should also be a light on the dash that says "Door Ajar".
If you find a switch not turning off, holler back. There are fixes for them.
caradiodoc
Aug 7, 2009 at 1:52 PM
THE SEATTLE GUY
thanks that solved the problem with the lights. but there is no door ajar light. This is an se model. do you think that might be a later addition?
Aug 8, 2009 at 9:23 AM
CARADIODOC
  • 34,413 POSTS
What solved the problem?
Aug 8, 2009 at 10:04 AM
THE SEATTLE GUY
The door switch on the front passenger side was not being pushed in. I screwed it out a little and now it works. There is still no do adjar indicator nor is there any time delayed shut off. Was that a feature of a different or later computer?
Aug 8, 2009 at 11:22 AM
