1991 Dodge Caravan DOES NOT SHIFT GEARS
160,000 MILES • 6 CYL • FWD • AUTOMATIC
AUTOQUESTIONER
CAN YOU TELL ME TO LOOK FOR A SPEED SENSOR ON A 3.3 l AUTO TRANSMISSON? AND DOES MY VEH. HAVE A SPEED SENSOR OR VACUUM MODULATER
Oct 31, 2009 at 4:57 PM
OBXAUTOMEDIC
  • 3,719 POSTS
Hello, Your vehicle is electronically controlled it has what is called and Input and an Output Speed Sensor they are located....
https://images.2carpros.com/forum/automotive_pictures/188069_91caravanspeedsensr_1.jpg
These Sensor are only about $15 - $20 each and I would suggest replacing these first to see if they fix you problem. Also have you checked the tranny fluid? If so what color was it and did it have a burnt smell to it. If so then I would try a tranny service. Change the Fluid and filter. Another posibilities is the Transmission Control Computer (ECAT Control Module) Located on the passenger side firewall near the strut tower. Or the ECAT Selenoid Pack check pic above for location. .
Nov 4, 2009 at 2:47 AM
