1991 Dodge Caravan
178,000 MILES • 6 CYL • 2WD • AUTOMATIC
SAMMIO
my problem is high hc value. it is 1500 ppm while idling. idle speed is not steady it`s running between 800 to 1100. i`M having error codes 26 and 54. i really need help becouse there aint so many dodge services in finland. sorry about my english. thanks
Dec 18, 2007 at 4:35 AM
MERLIN2021
  • 17,250 POSTS
The codes are 26=Fuel injsector control circuit or engine temp sensor.
54=no signal from crank sensor...try replacing the crank sensor first then clear codes, and see if light comes on again..
Dec 18, 2007 at 4:44 AM
