won't turn over
JOE71
Engine Mechanical problem 6 cyl Front Wheel Drive Automatic
Everything seemed to be fine I went somewhere shut the van off when I went to restart it it wouldn't turn over it sounds like it wants to but it just won't.I have plenty of battery and gas however I have nothing else.
Aug 31, 2008 at 8:07 AM
  • 75,988 POSTS
I assumed that it cranks over and refuses to start-if so do below to determine if its fuel or spark problem.
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
Aug 31, 2008 at 8:13 AM
