1990 Dodge Caravan General question
TANDER78
Engine Performance problem
1990 Dodge Caravan 6 cyl Front Wheel Drive Automatic ? miles
Hello-
In the car mentioned above, the engine is the Mitsubishi 3.0 SOHC which has a distributor and port injection. What is going on is the van will on occasion start, then it idles very irratically then dies. I understand that the distributor has a "hall effect" switch and I am wondering if that switch controls when the injectors inject fuel being that the enigine does not have a cam position sensor. Also, it has been my expierence that a fuel pump works or does not but in this case, can a failing fuel pump create this problem? Thank you for your time and suggestion.
Todd
Aug 8, 2009 at 12:50 PM
BMRFIXIT
  • 19,053 POSTS
Very much would need to have the fuel pressure checked
Aug 8, 2009 at 1:03 PM
