1990 Dodge Caravan Fuel Pump or Fuel Filter
110,200 MILES • 6 CYL • 2WD • AUTOMATIC
COUNTRYPUP
As I'm driving I start losing power as if the car isn't getting gas. It hesitates and all of a sudden it jumps as if getting as boost of fuel. Could this be my pump is failing or the filter needs to be changed?
Feb 16, 2008 at 6:26 PM
BMRFIXIT
  • 19,053 POSTS
[quote:4e8e26e18f="Countrypup"]Other Category problem
1990 Dodge Caravan 6 cyl Two Wheel Drive Automatic 110200 miles
As I'm driving I start losing power as if the car isn't getting gas. It hesitates and all of a sudden it jumps as if getting as boost of fuel. Could this be my pump is failing or the filter needs to be changed?[/quote:4e8e26e18f]
check the fuel filter
check tune up
try to get a fuel pressure test
and spark test
Feb 17, 2008 at 1:32 AM
