1990 Dodge Caravan fuel pump
OBIE
1990 Dodge Caravan 6 cyl Front Wheel Drive Automatic 180/00 miles
I am replacing the fuel pump in my 1990 Dodge Caravan and have it loose from the tank but there is a hose connected to the bottom of the pump and it goes back inside the tank. I can't figure out how to unclamp the hose. The clamp is different from what I know.
Jan 20, 2009 at 9:32 AM
TONE94SHADOW
  • 8 POSTS
Im not 100% on this one but if it is a plastic tube that goes back into the tank and only looks like half of a sending unit then the other half is still in the tank and there is 2 relse tabs one on each side of the remander in the tank be careful not to brake the tabs. use a flash light to see if this is the type if you look inside the tank you will know if is this type or not
Jan 26, 2009 at 10:34 AM
