1990 Dodge Caravan buning rich
SHADOWBEASLEEP
Engine Mechanical problem
1990 Dodge Caravan 6 cyl Two Wheel Drive Automatic
van has no exeleration very little going up hill ,black soot around tailpipe but not smoking has exhaust issue .van has died a couple of times going down road thought maybe vapor locking. if burning rich causes would be?
Aug 8, 2008 at 5:48 AM
  • 75,988 POSTS
Could be caused a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Aug 8, 2008 at 6:00 AM
