1989 Dodge Caravan NO GO
215,000 MILES • 4 CYL • FWD • AUTOMATIC
MZHUSTLER
CAN START THE VAN AN IT IDLES FINE. BUT AS SOON AS YOU PUT IT IN GEAR IT DIES IF YOU KEEP YOUR FOOT ON THE BRAKE AN THE GAS IT WILL MAKE A POPPING SOUND OUT THE CARB. AND THE BRAKE PEDAL SEEMS STIFF AT TIMES LIKE THERE IS NO BRAKE
Apr 21, 2009 at 5:17 PM
  • 110,244 POSTS
The stiff brake sounds like there is a major vacuum leak. Check the hose that goes to the brake booster to make sure it is connected and not broken.
If it is good, have the booster vacuum tested.
Let me know what you find.
Apr 29, 2009 at 3:30 PM
