1989 Dodge Caravan Gas Problems
1989 DODGE CARAVAN
JENNELLED
Engine Mechanical problem
1989 Dodge Caravan 4 cyl Two Wheel Drive Automatic
The first problem is that my car will only run 1 time in like 2 days. When it does start I have to immediately drive off and cannot stop at the stoplight without having my foot on the brake and on the gas and pressing the gas down constantly. The second problem is that I go to fill up at the gas station and I can only put a couple cents in the tank and then I have to wait about 30 seconds and then put in a couple more cents and so on and it takes about 30 minutes to fill up the tank.
Jul 1, 2009 at 2:00 PM
  • CERTIFIED EXPERT
  • 110,175 POSTS
Has the check engine light come on? When you remove the fuel cap, is there a vacuum? Also, there is a check ball where fuel enters the tank. It's designed to prevent fuel from leaking in the event of a roll over. It could be sticking not allowing fuel to enter the tank.
Jul 3, 2009 at 5:04 PM
JENNELLED
no the check engine light has never came on and yes there is like a vacuum sound when there is no gas in the tank like when its empty
Jul 4, 2009 at 1:00 PM
  • CERTIFIED EXPERT
  • 110,175 POSTS
There is a fuel tank vent (I believe it's behind the fuel tank) that I think may not be working. You may want to have that checked.
Jul 6, 2009 at 4:07 PM
