1989 dodge caravan cv joint replacement
WCRISCOLA2K3
i would like specific info on how to remove and replace the driver side cv joint on a 1989 dodge caravan with a 3.0 liter, front wheel drive only.
Nov 4, 2007 at 7:57 AM
BMRFIXIT
  • 19,053 POSTS
[quote:cfeb830a97="wcriscola2k3"]i would like specific info on how to remove and replace the driver side cv joint on a 1989 dodge caravan with a 3.0 liter, front wheel drive only.[/quote:cfeb830a97]
Jack car up and secure
Place drain bucket under the tranny
Remove tire
Remove caliper brakes brake rotor
Remove lower ball joint bolt
Remove axel nut
Pull lower ball joint out of the spindle
Pull axle out
Play it safe
Good luck
Nov 4, 2007 at 11:56 AM
