1989 Dodge Caravan
HUGOCESARJR
Steering problem
1989 Dodge Caravan 6 cyl
how do i disconect the rack and pinion from the steering shaft their a u joint what tools do i use?
Jul 26, 2008 at 1:03 PM
BMRFIXIT
  • 19,053 POSTS
rack and pinion removal and installation
let me know if more is needed
good luck
Removal
1.Disconnect hoses from steering gear (if equipped). Raise and support vehicle. Remove front wheels. Separate tie rod ends from steering knuckles. Disconnect engine damper strut from crossmember (if equipped). 2.Support front suspension crossmember with floor jack. Remove front suspension crossmember bolts. Lower front suspension crossmember so steering gear can be disconnected from steering column. 3.Remove steering gear retaining bolts. Remove steering gear. The steering column coupling will disconnect from the steering column.
Installation
1.To install, reverse removal procedure. On manual steering gears, ensure serrations are aligned. During installation, an assistant will be needed to align steering column coupling with steering column. 2.Install all crossmember bolts. Tighten RIGHT REAR crossmember bolt first. Install remaining components and fill steering gear. Adjust toe-in. See WHEEL ALIGNMENT SPECIFICATIONS & PROCEDURES article in WHEEL ALIGNMENT section.
CAUTION:Tighten RIGHT REAR crossmember bolt to specification prior to tightening remaining crossmember bolts. ALL crossmember bolts MUST be tightened to 90 ft. lbs. (122 N.m).
© 2007 Mitchell Repair Information Co., LLC.
Jul 26, 2008 at 3:01 PM
